cheapskete OCer
i dont see much of car audio on here ..but im getting this amp for my car off ebay and it says this on the specs Thunder 204 Amplifier
RMS Power measured at 12.5 Volts DC:
25 Watts x 4 into a 4 Ohm load with less than 0.1% Thd+N
50 Watts x 4 into a 2 Ohm load with less than 0.3% Thd+N
100 Watts x 2 bridged into a 4 Ohm load with less than 0.3% Thd+N
Dynamic Power (IHF-202 Standard) measured at 14.4 Volts DC
65 Watts x 4 into a 4 Ohm load
125 Watts x 4 into a 2 Ohm load
250 Watts x 2 bridged into a 4 Ohm load
Signal to Noise Ratio:
110dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-20kHz±0.25dB
Maximum Input:
8Vrms
i dont know anything about ohms...but how is it i get 125w x4 in 2 ohm versus 65w x 4 in 4 ohm.....and how are you able to choose what ohm you run in.......thanks
110dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-20kHz±0.25dB
Maximum Input:
8Vrms
