Odd Speakers and Other Curiosities
  • Thread starter Thread starter Pogre
Also found these Infinity Reference Standard II's for $1800. Recently refoamed and otherwise in pristine shape.
View attachment 35866View attachment 35867View attachment 35870View attachment 35871View attachment 35868
They do look impressive!
I picked up a set just a month ago.
No grills so
in process of making some custom grills now.
Sent from my SM-G988U using Tapatalk
No grills so
They're very impressive looking! They have good pedigree too. How do you like them? They look like they could be actual full range speakers.
Been running them two channel only for about a month. Picked up an Outlaw 7500 amp at the same time to drive them. Woofers and mids have been refoamed. EMITS are in great shape, as are the cabinets.
Plan on breaking them down soon to refinish them after I complete the grills and clean /lubricate the pots.
Overall they sound as good as I remember them back in the 80's. Once everything is complete maybe take some sweeps with REW and see how they measure up.
Specifications:
Frequency Response: 36 -32,000 Hz ±2 dB Sugested for use with Amplifier of: 35 - 250 watts per channel
RMS Drivers (each channel)
Woofers: Two 10" (25 cm) with polypropylene cones in Infinity/Watkins dual-drive configuration.
Midrange: Three 5" dipole drivers with polypropylene cones in dipole configuration.
Tweeters: Two EMIT, one of them facing rearward
Nominal Impedance: 4 ohms
Dimensions (W x H x D): 580 x 1220 x 460 mm (22 ¾" x 48" x 18") Weight (Packed): 45,5 kg (100 lbs)
Finish: Solid oak diffractions wings. Oak veneer over high-density particle board woofer enclosure.
  • Like
Reactions: KEW and Pogre
Okay, Miller and Kreisel speakers. I keep coming across them and dismiss because they're pricey for what they are. I'm not familiar with them either so that makes them oddballs in my experience. Here are 2 examples available in my area now.
A satellite speaker? Kinda bulky for a sat, lol.
All that foam looks like something the owner added on their own...
No grills so
Nice! Those Infinity's were some of the most highly regarded speakers of their time.
View attachment 35937View attachment 35936
View attachment 35939View attachment 35938
No experience but the older M&K stuff was pretty good by most accounts, and early adopters of sat/sub systems.....the latest resurrection of the brand not so much....maybe this would be helpful https://www.kreiselsound.com/timeline.php
  • Like
Reactions: Pogre
Oh I've passed on them many times now. I'm wondering if it's some way to customize your own house curve or... hold up...
Or you're absolutely correct! It's like you have a spider sense for this crap! Ha ha.
RC Networks: All Merlin TSMs come with a pair of RC Networks. What are RC Networks? They are simple a resistor capacitor network (sometimes referred to as a Zobel Network in design circles) that mounts across your speaker terminals. The network acts to terminate the speakers load out past the audio band up into RF regions (this keeps amplifiers a bit more happy) and they also act a shunt or load for RFI energy that appears at the speakers terminals (whether picked up by the speaker, the speaker cables, are fed from further up the line in your HiFi system). The result is a cleaner and more uniform sound from the speaker/amplifier system. Merlin has learned over the years that the quality and type of parts used to make the RC Network are very important and do have a impact on the sound. The Standard RC Networks are made with a Cryogenically treated Hovland capacitor and a Caddock Metal Film deposition resistor and Cardas wiring. The Master RC Networks use the (very good & expensive) hand made Deuland capacitors (see BAM Differences above for the impact these caps have in the Master BAM – they do much the same thing here) and cost much more than the Standard RC’s.
I really was trying to follow that, then I got to the "Cryogenically treated" part...
Zobel networks are legit.......the cryo stuff is snake oil
I'm familiar with Zobel networks (read up on them when I had my Deftech SM55s, which use the same).
They way I understand it, on the Merlins it's basically a crossover/filter (cryogenically treated!!!) you can adjust by changing the wiring scheme on the outside of the cab, right?
I'm not sure what Merlin is trying to accomplish there, and it seems odd that it is mounted external.
Classically, Zobel Network is used to counteract a phase shift to get a purely resistive load as seen by the amp.
Look at my Avatar. It shows the impedance and phase angle curves on a 2-way speaker box which I built 5 years ago. Obviously, that speaker design was easy to drive.
I always add a Zobel network in my passive crossover designs unless the size and the cost of the required capacitor become inconsistent with the cost of the other components.
An engineer whom I knew once mentioned to me that Dynaudio used to, but I don't know if they still do, add Zobel networks for all drivers in their passive crossover designs, and even on their tweeters.
Never heard of these before. If I had money to burn I'd give em a shot. Looks to be undervalued at $800 honestly.
The cabinets remind me a little bit of my Ultra towers.
*Edit: Those do look very nice. I notice they have a contour switch to adjust for some possible room modes too. Are those usually more gimmicky or actually useful when designed and implemented correctly?
I tend to see such switches more often on the backs of Studio Monitors vs. consumer speakers. That tends to lead me to believe that they are useful in certain situations, like non-ideal placement options.
I saw these the other day. There are some interesting speakers being created by really small boutique companies.
