In my book you will not make a poorer speaker sound better than a superior one with room treatment.
I think this statement probably sums up what I perceive as a misunderstanding that underlies this thread (and others where TLS and I - and others - have exchanged niceties). No one is arguing that you can ignore loudspeaker performance if you simply address the room. What you say above is true, TLS, but it's not the point. The point is that a poor loudspeaker in a
treated room
can sound better than a superior one in an
untreated room. Following from that, a superior loudspeaker in a
treated room can sound better than
the same in an
untreated room.
And, as I have pointed out to you before and as others have pointed out to you here, "treatment" does not necessarily equate to "kill all the reflections and make an anechoic chamber." This is ground already covered...
Well actually modern science rather mucks up live concert venues! The classic case was London's Kingsway Hall. That hall had a nigh on perfect acoustic. It was a wonderful recording venue. For a listen the recordings of Sir Adrian Boult conducting Elgar's the Apostles and the Kingdom are one of the greatest achievements of the recording technology. Well Unfortunately men of science got involved in a make over, and now it is a dog and no longer a choice recording venue.
"Modern science" has given us many fantastic sounding concert halls. An entire branch of applied physics cannot be condemned on the basis of one "classic case." Admittedly / sadly, there are others, but great sounding "modern" halls far outnumber the "dogs."
The best concert Hall's in the world are those prior to 1900. Examples are Vienna's Grosser Musikvereinssall (built in 1870), Leipzig's Gewandhaus (1885), the Concertgebouw in Amsterdam (1895) and Symphony Hall in Boston (1900).
As an opinion, I respect this (and I wouldn't necessarily disagree). As a fact, it's false. One need look no further than Beranek's books (
this one being just the most recent) to find countless examples of great sounding halls designed and built after 1900.
It seems that concert Halls of shoe box design are best. Lots of lateral random lateral reflections, especially lots of early reflections within the Hass fusion zone give the most pleasing effect, with a total reverb time of 1.6 to 2sec. For liturgical music reverb times of 3 to 4 sec give the most pleasing effect.
All valid points...and all things that can be designed into halls even if they aren't of the classic "shoebox" design, btw.
I have found in listening rooms dead ones are very unpleasant. I have found speakers with limited vertical dispersion or those lobing downwards give the most pleasing effect. Of course the off axis response must closely mirror the axis response. I have also found that rooms such a my lower level living room that has a distinct echo can also sound very pleasing, especially when reproducing liturgical music.
I would only comment (again) that no one here is advocating a dead listening room.
Now there is a difference in the requirements for reproducing pop, rock, and jazz where a more dead acoustic is apparently preferred. However I don't listen to that.
A good point. What works for you may not work for others!
For music I listen to, a dead room does not produce satisfying results. I have used very high performance monitor class speakers for the surrounds, especially the center backs. On good SACD the original acoustic is reproduced with uncanny accuracy. I also find on a lot of good recordings the the Dolby PL IIx does a remarkable job of recreating the original acoustic.
On good recordings this space sounds much larger than it is. Good recordings in cathedral spaces, sound far in the distance as they should, and a wonderful sense of ambiance. Now those recordings really reveal the shortcoming of lossy compression algorithms. As soon as switching to one, even MP3 at 320 Kbs, the ambient field just collapses.
All very interesting. But (again²) we are neither advocating a dead listening space, nor are we telling you you should change your room. Glenn has only made suggestions to you about testing your space and/or listening to your system in a treated space simply as exercises that he believes may offer insight about what acoustical treatments can do. I am very confident that you would probably stick with what you have, all evidence and opinion to the contrary. And that's fine. But, as you pointed out above, what you have may not work for others. And that's a good thing to remember when giving people guidance and advice.
Despite what you may believe, we all share the common goal of helping people achieve great sound in their listening rooms and home theaters. Your opinions on the matter are always extremely helpful and insightful. Personally, I welcome the opportunity to discuss such things with someone with as much experience as you obviously have. But flat-out condemning the opinons of others - regardless of whether you believe them to have ulterior motives (not all of us do, btw
) - moves us away from the goal. We all benefit from keeping things civil.
