What do you suggest then TLS? I don't think that "flat" response sounds very good, personally. But what ideas to you have to help the OP out? I'm curious as well to get ideas on how to make my setup sound better.
I knew this would heat things up. I should by now know when to keep those quips to myself.
However sometimes a thread opens up to a great misunderstanding in audio, and an area rife with error. This is one such.
The area hinges on the huge misunderstanding of what speakers are capable of and their severe limitations. Really the route to good audio is the sum of compromises, and not inadvertently going down a train of thought where you end up precisely wrong.
Lets look at this another way. If you had a group of one to four good instrumentalists with acoustic instruments in most of the members listening rooms, it would sound darn good. Now if that performance was recorded with fine studio microphones handled with intelligence, than when played back it should still sound good. I'm sorry to have to tell you the speakers that will rise to that challenge are far and few between.
During my 30 odd years in Grand Forks, I have had the opportunity do do just that for UND student audition tapes etc.
Now all the room reflections etc. are going to upset a flat room response to a degree. However the live performance is going to sound right in all but the oddest of rooms.
So if your speaker is lacking, is Eq the answer. Used intelligently with a good pair of ear lobes, it can help. However my experience tells me you can never completely correct a speaker that is wanting.
Now frequency response errors in speakers are usually accompanied by other problems in the region of the errors. These include but not limited dispersion problems distortion, phase and time delay problems.
The other problem is the power response of the speaker. This is especially true in the bass. Every time you correct by 3db you are doubling the power required of the speaker at that frequency. Now a ported speaker completely decouples from the air rapidly below system resonance. If you Eq, all you produce is distortion, frequency doubling and the high chance of driver damage due to excessive cone excursion.
If your measuring records some aberration in the HF, tweeter overload and burnout are risked.
Unless you are very skilled, and have invested in good test gear and have the skill to use it, then Eq by ear with a thoughtful subtle touch is the best way to go. By that I mean one to three db cuts or boosts here or there. I have NEVER seen more drastic Eq than that do anything but harm.
The next issue, is the thorny matter if integrating speaker and sub. Now for movies the standard Lucas approach is I suppose fair enough. I don't buy that you can have a limited pair of speakers and turn them into fantastic audio reproducers by the addition of a sub.
My view is that Joe Schmoe is not all wrong if you have followed some of his threads. Far from it!
Really, having a good pair of left right speakers that stand on their own merits is the very foundation of a good audio system, in my view. If they can't by themselves produce a believable satisfying sound stage without the temptation to tinker, then you are off to a bad start and have an up hill, if not impossible, climb.
Really I think the best results from an audio point of view is having a set of speakers that gives a very satisfying result full range and gently extending their range with a sub of comparable quality. This of course done with intelligence and subtlety. As I have said before sub to speaker is a crossover with ALL the ills that entails. Minimizing the chance for error in regions in which the ear is sensitive is a good plan.
And then we haven't mentioned the center speaker, but I have posted on this before. As I have said before the center speaker and getting it right is perhaps the toughest challenge confronting the speaker designer.
