NTSC vs PAL AVR concerns
I'm from the US (NTSC) but now live in Thailand (PAL) and will be going back to the US in a couple of months.
The camcorder I'm buying from the US is PAl format so I can use playback here after the trip. Easy enough as I underastand the differences....
However... I also plan on picking up a decent AVR in the US to carry back here for a number of reasons, price and availabllity being first and formost.
On basic searches I found sites that promote their...........
EXCLUSIVE! We carry the World Wide version that works in any country!
Yamaha AVENTAGE RX-A2030D A/V RECEIVER 9 CHANNEL.Works with NTSC and PAL on 110-240 volts 50-60 hertz.
"Our model has a voltage selector switch to set the voltage. It is not modified in any way. It comes like this from the Yamaha Factory!"
So really it's not an "exclusinve"at all, as it comes from the factory with the dual voltage switch.
Question 1: Can I assume that most AVR's are dual voltage as with computers?
(I can buy 110 to 220v transformers but they don't address the 60 to 50 Hz)
Question 2: Should I be concerned about PAL and NTSC formats on the AVR like the camcorder?
In other words, if I buy a decent AVR in the US (NTSC) will the pass thru format to the TV (PAL) in Thailand matter?
Same with a Blue Ray player... any concerns I need to worry about or is it
"garbage in, garbage out"?
Thanks in advance for the time and
