Re: "What are you running?"...
...rum, guns and Cuban cigars...ooops! no, no, no, it's a joke Big Brother...
Anyway...a Philips 212 Electronic TT e/w a Stanton 881s cart, which is sitting in(on) and custom support fitted with AudioTechnica self-leveling,shock-absorber feet...a BSR Macdonald/Heathkit changer e/w a Stanton 681EEE/conical stylus(for my 78s)...My TEAC A-650 finally gave up the ghost and has been temporarily replaced by a Marantz SD-4250 twin-well unit...A TEAC A-3440 simul-synch four channel RTR...Until recently a Pioneer TX-9100 AM/FM tuner, a Pioneer SA-9100 integrated amp(both of which are down at present...the tuner has some MPX problems and the amp a self-triggering protection circuit gremlin...probably will be dealt with over the winter months)...in place of them I'm using an Onkyo mini-system(MC-35TECH), the 3CD changer for CDs(in place of the JVC DVD/CD player I was using...it's now plugged into a compact GE selector switch along with my SONY vcr and into my Philips/Magnavox tee-vee...see no HT...) and the tuner/amp(their description) as a head unit...since there are no pre-outs, it's feeding out of the headphone jack(!!!oh, mon dieu!!! too lazy to build a dividing network) into an SAE Mark2700B half octave EQ...into the HK Citation 16 and powering the Bose 901-lls...I also have a pair of STAX SR-44s and a pair of Sennheiser 212s...Used to run a Sound Concepts SD-550 feeding the power amp section of the integrated as part of a ambience recovery scheme with Bose 301s as the rears(hafta' keep that "sonic signature")...they too were EQd, this time with an Audio Control one-octave unit.
It may seem like a mish-mash of ancient stuff, but, when the integrated went south and before I got the Onkyo stuff, I could run my TT through the smaller EQ to mimic the RIAA curve, then thru the amplifier section of the RTR and viola!...music...
Well, you asked...
$7500!!! Yikes, for mechanical lizards and laser-beams??? For about a 3k wide bandwidth!!!
privateer said:
So why would you blow all that money on bose when for half the price you can have speakers that play louder, cleaner, and still hit the 20Hz to 20kHz.
Actually, for about $1k, I think a 2-channel system that would provide better than 90-95 percent of much more expensive systems could be built...
Recall, that Onkyo mini I mentioned earler...I did some futzing around before I grafted it into my main stereo...I had to loosely stuff the speaker ports, invert the enclosures(a la Mission) and used some arts'n'crafts felt to tame some of the high-freqs and reflections...a little judicious use of the tone controls and hey...pretty d@mned good...I'm thinkin' a Polk 50W sub would fill in the blanks, obviating the use of any bass-boost...and since I have a problem with the single-sub-summing of bass freqs, I'd actually go for two of 'em...so there's 50Wpc on the bottom + 20Wpc for mids and highs...given my inefficient 901s do around 85db with only a 2.5W output, I don't think any more power would be required...anywhere from $600-800 even at MSRP...downside: no phono...
Of course the is no real potential for expansion, but for a simple stereo set-up it would do real good IMHO.
Then there are other possibilities...maybe an Onkyo TX-8511...perfectly respectable but w/o pre-outs or "tape-mon" pretty much a dead-end expansion-wise...
The Marantz SR-4320 has pre-outs but no true "tape-mon"...no biggie if you don't need it...their PM-7200 is a real disappointment in that it has no "pre-outs" so no expansion with this one...otherwise very promising, you can even run it as a 25Wpc class A amp...good connectivity tape-wise...
Denon's DRA-685...Nice...80Wpc..."pre-outs/pwr-in", phono AND true "tape-mon" plus Zone 2 capabpility...
HKs HK-3480, also nice IMO...120RMS per and lot's of connectivity...
Couple any of these with a decent CDP and some speakers...I think some Bose Acoustimass might be a good starting point, maybe Polks... and for around a grand...bada-bing, bada-boom...music.
jimHJJ(...feel free to pick nits...)
