Not possible to use Aux cord (3.5mm) from Laptop to Denon 2309CI?
jliedeka
jliedeka
My MacBook Pro doesn't work with my Marantz hooked up with a 3.5mm to RCA cable. Oddly, my phone and Android tablet work fine. I haven't tried my iPad Mini yet.
Pyrrho
Pyrrho
It could be a setting in your computer, or it may be that the output jack on the computer is defective. It would be good to try hooking it up to other things to see if you could get it to work with anything. For checking the settings, going to a site devoted to Mac computers should be the place to get good advice on how that should be done.
You know the Marantz input works because you have used your phone and tablet with it, so that can be eliminated from consideration. It is obviously something about the computer, and if I were to hazard a guess, I would guess that you have some setting wrong. Though, again, it is also possible that the output jack or connection to it is defective, so it could be a hardware problem, but most of the time with this sort of thing, I think it is a software setting that is the problem.
BoredSysAdmin
BoredSysAdmin
Most Macbook pros 3.5mm "headphones" port is also an optical (aka toslink, aka spd/if) out.
You'd need this adapter to connect to your avr:
HDMI Cable, Home Theater Accessories, HDMI Products, Cables, Adapters, Video/Audio Switch, Networking, USB, Firewire, Printer Toner, and more!
I hope I don't need to explain the benefits of digital connection :rolleyes:;):p
p.s: To OP, your title doesn't say jack. You need to specify the make and model of your laptop to get at least somewhat of relevant answer
markw
This is the kind of post that shows me where BSA got the inspiration for his sig line.
You guys can play 20 questions if you want but I'm not even gonna bother until this joker decides to give some information, like what he's trying to do, and in what domain.
BadgerAVS
Yikes, takes one mistake and this forum turns into a Chicago Pub and I'm the guy who comes in sporting a Packers Jersey.
jliedeka
jliedeka
The jack on my MBP works with headphones. The RCA cable uses the same plug so why wouldn't it work? The level might not be right but there should be sound.
Jim
