Noob Needs Help Picking a Receiver
djkyle65
I have around 250-300 max to spend on a receiver im looking at the
Onkyo TX-SR506 7.1 Channel Home Theater Receiver
or the
YAMAHA RX-V461 or 661
Any suggestions
Thanks Kyle
Seth=L
Seth=L
or the
Any suggestions
Thanks Kyle
Yamaha RX-V661 by a landslide, it's got the best amp section, most connectivity as well as features, and is the only receiver mentioned that supports HDMI audio. The only thing it lacks is HDMI 1.3 pass-thru, which honestly few people will ever utilize.;)
mazersteven
mazersteven
YAMAHA RX-V661
What speakers are you trying to drive?
djkyle65
Is it worth the extra 100 to get the 661 I will probably never use the hdmi
mazersteven
mazersteven
Polk Monitor 50 Fronts
Polk Monitor 30 Rears
The 661 will drive these speakers with ease. Also if your thinking of up-grading your speakers in the future it is kind of a future proof purchase right now.
Seth=L
Seth=L
What about the v659
If you know you will never use HDMI, then the Yamaha RX-V659 is a superior machine in terms of amplifier power, and cheaper. You can basically drop all the receivers mentioned in the opening post if you know you will never use HDMI.
djkyle65
Yeah ill probably go with the 659 and if i do hdmi later ill just go directly to the tv.
Seth=L
Seth=L
There are other advantages to using HDMI audio other than convenience, just FYI.;) Those advantages can't be had if you run your HDMI straight to the TV/display.
djkyle65
What other advantages would that be?
If i ran hdmi to the tv and used the digital outs into the receiver wouldn't that be just as good ?
Seth=L
Seth=L
No, not if you get into Blu-ray. Blu-ray supports HD audio over HDMI, as well as 5.1 analog connection if the Blu-ray player supports it. Most Blu-ray players don't support HD audio over 5.1 analog outputs and HDMI is by far the most practical way to handle HD audio (up to 7.1 lossless sound).
Suds
How much better would the Yamaha RX-V659 be over the Onkyo TX-SR505 if you don't need HDMI? I'm also looking into getting a receiver and have no need for HDMI.
