So I just installed a Denon AVR-S700W, and everything is working perfectly. Im using my old sony tower speakers from my last system, mostly the upgrade here being the receiver and a new center speaker.
Everything works so far except I cant get any sound from the subwoofer, or any speaker in its place. The back panel has it labeled 'pre-out' with the only thing there being 'subwoofer' underneath that. Its a passive sub with its only input being the + & - bare speaker wire, while the receiver has an RCA connection. I tried to DIY an rca to bare wire, but that hasn't worked.
Passive sub, bare wire spring clamp
AVR-S700W, ACR pre-out subwoofer connection.
Im trying to figure out if its the cable or a problem with the AMP itself here, Ive adjusted levels in the receivers menus, but cant get any sound to come out of the channel- at all. Could this just be a problem with the 'DIY RCA to bare speaker wire' thing I was told to try? Or is this a fault of the amp?
