no sound on the oppo
abefroeman
abefroeman
I just bought an oppo 970 and I can't get the sound to work. I admit that it is probably user error, but I have tried everything that the manual says in order to fix the problem.
My first thought is that it was a connection problem. So I setup my old dvd player and played a movie, the sound worked. Then I unplugged the red and white from that player and plugged it into the 'mixed' signal on the oppo. no sound. I know everything else in the system is set correctly because the old player was working.
Has anyone else had this problem? what is the likely solution?
I have checked:
- mute
- player volume
- the 'stereo' vs. 5.1 channel settings
- all the remote buttons
- all functions in the audio setup menus
abefroeman
abefroeman
I talked with the tech guy at oppo and they are replacing the unit.
they pay shipping both ways,
pretty cool.
ParadigmDawg
ParadigmDawg
So it was the unit? Sorry no one responded to your needs.
abefroeman
abefroeman
Yeah, I believe so. I had a conversation with their tech guy and when I explained how I had it setup he said its must be the unit, so they are replacing it.
abefroeman
abefroeman
The replacement player came in the mail a couple weeks ago. works great!:)
As a total layman on video stuff, I would not say that it the new player is night and day better than a regular dvd player, but it is definatly less grainy. It does not have the 'wow' that true HD has, but it looks good to me.
KC23
KC23
Glad to hear it all worked out okay. Enjoy. :)
