yes. that's right.
currently my players (DVD and HD players) are all hooked up via HDMI 1 and HDMI 2 to TV connectors.
While to Amp is via RCA cables
I thought you were trying to get HDMI audio from your TV!
You should be able to get an analog audio output from an HDMI connection.
You have to assign inputs to the devices, doing video and audio separately I think.
Page 21 is the only area where I believe it speaks to this issue.
Assign devices
After connecting devices, assign the device
attached to each connector. This allows you to
easily identify devices connected to your TV.
1 Press ( Home ).
2 Press OK or .
3 Press or to select a device and press
4 Press or to select the connector
your device is connected to and press .
5 If available, press or to select the
audio connector your device is connected
to and press .
