Denon_Jean said:
...the sound comes out, but the light doesn't come on...
I can think of one way to confirm that it's not simply a defective receiver front panel display (which is highly unlikely):
Even though the DD indicator isn't lit up, what about the little 'speakers' on the display (i.e. L, C, R, SL, SR, LFE)? Are they also not lit up?
If, as J Garcia and myself suspect, that the problem lies either with:
- The DVD player's menu not correctly set to instruct the player to output the raw data to the receiver, or;
- The receiver currently being compelled to decode for example in PLII as opposed to being set to AUTO detect mode;
...then
only the L and R little 'speakers' on the receiver's front panel will be lit when playing any normal DVD. If however, the L, C, R, SL, SR and LFE 'speakers' are lit but DD (or dts if selected on the DVD disc's own menu) is
not, then you may well have a problem.
The solution to points 1 and 2 maybe found in the DVD player and receiver's menu respectively (now if Denon's website only allowed the downloading of their manuals, I could help you find the parts to read).
