pjoseph
Well just picked this up yesterday....
Now from reading around I believe that this should not work using the digital (optical) output on the PS3. It has to be setup to do the audio through HDMI.
So switched it around changed it to audio through HDMI and it does not seem to get loud at all. My receiver is reading an Analog signal as well not sure if that is correct.
So i tried it the other way through digital output (optical) sounded better but only had 2 channels comming in according to the receiver. I belive it should be 5.1.
Any ideas
I am using a marantz sr4001.
thanks
Any ideas
thanks
