LostnProjection said:
I purchased an Optoma HD72 about a month ago and after finding a permanent location I decided to ceiling mount it. I just wanted to know if anyone had any ideas or possible solutions other than buying the $300 mount from optoma. If it turns out that the optoma mount is the only solution then I don't have a problem buying it, I was just wondering if there are other ways to get this thing ceiling mounted.
thanks in advance for your input and I apologize if this has been covered before.
There must be another way
Since you have it in hand, you know where the mounting holes are on it. You also know how far down from the ceiling it needs to be. You also know its weight. If you are handy at making things, you could fabricate a mounting plate to mount to the projector, the ceiling and depending on visual looks, in-between the two plates, perhaps a 1/1/2" pipe?
If you are not a DIY person, better buy the factory item, or search the web for a universal that would support your projector.
