newbie! what happened?
bleedmx
newbie! what happened/ its fixed
ok i will try to keep this short I have a Yamaha HTR5860 initial music and
surrond volumes started in the -db mode (-55db) and as you increased the volume it would go towards a positive db reading (example -20db) louder than (-30bd) with +16db being the loudest, as you all probably already know.
I dont know if i did something or what but the music still functions the same
however surrond can not be heard below -5db with +16db being the loudest also however not as loud as used to be. almost as mute is on, which it is not
hope someone can help me and thanks in advance if so.
N
Nick250
It sounds like a setup issue. I suspect if you took a few minutes to re do basic setup as outlined in the manual, the problem will come to light.
Nick
jcPanny
jcPanny
Auto Setup
Bleedmx,
I have the same Yamaha model. Plug in the Mic and do the autosetup so that the receiver will adjust the speaker levels properly. This Yamaha allows you to adjust the settings on the fly using the remote or front pannel so someone might have accedentally changed them.
bleedmx
thx for the ideas Ifigured it out, i'll tell you this in case someone else does the same idiotic thing I did somehow the variable/fixed output on the TV
got switched put it back works great
and thx for the ideas
