<font color='#000000'>Hello,
Thank you for the info. As I said, I RARELY listen to music at that level and for very short periods of time. However the sound was clean even at that listening level (although, as you can probably tell by the equipment I own, I am not an audiophile, so perhaps there WAS distortion without me even knowing it.) However, if I play at 50% volume (the readout on the receiver reads "Volume 50"; I assume it means 50%) the sound is audible but nowhere near loud. My old Technics produced more sound at half-volume, and that was the maximum it could put out before clipping. The Integra is putting out less sound at half-volume than the old Technics. Why? That being said, it seems that I can get cleaner and louder sound from the Integra as opposed to the Technics, but I definitely have to put the volume considerable higher than half, I would say probably at least 65 to 70%. Usually the loudest we go is 75% and quite rarely 80%. The 85% indicated in the previous post was the first time.
Shouldn't I be able to use higher volume with the Integra without distortion?</font>
