Newbie Question re: Denon AVR 3805
Miamienesex
The online manual seems to have all the answers although tedious to read, I also found Denons tech support interesting but helpful. So far the receiver is working better than expected. I am sure that once I upgrade my speakers the experience will better itself. Should I open another thread regarding speakers........... I promise not to buy them off the back of a truck:D
Armando
Geno
Geno
About Denon receivers being user unfriendly: I'd describe it as more complex than unfriendly. True, the manuals are not what they should be, but their mid - to - high end receivers are loaded with features not meant for novices or people who just want a 5-minute plug-n-play experience. I have a 3805 and 4306, and spent quite a a bit of time learning the ins & outs of setups. After finally getting things right on my 4306, I must say the results are well worth the effort.
Most of the higher-end AV receivers that I've seen on the market are equally complex just because of the sheer number of features.
Miamienesex
Here's another question for the experts.....
When playing either a DVD or Satelite movie with 5.1 , the screen on the Denon shows all 5.1 speaker icons. When a DVD is played using the DTS track it shows only 2 speaker icons. I have the DVD connected using the optical output.
Is this normal or are there additional buttons to push?
Thanks again.
Armando
MDS
Most likely there is a setting in the dvd player for DTS and you have it set to PCM instead of Bitstream so the player decodes and downmixes to 2 channel and that is why the receiver shows it as a 2 channel source.
Miamienesex
"You Are Correct Sir" :)
Amazing difference, thanks again for helping this newbie out.......
Armando
billy p
billy p
Now this is how it should work hahaha..!Hey ARMANDO just keep asking the question cause you 're
helping me too!GREAT AVR BUT A LOT TO LEARN:D BILL
Miamienesex
Glad I could help....... Here's another:
Can the source description on the Denon be changed to display what it's actually sourcing? ( Instead of displaying DBS can it be changed to read XBOX for instance?)
Armando
Geno
Geno
Armando
Nope. You have to move up to the 4306 to get that.
Miamienesex
Thanks, but since I just purchased an open box 3805 and almost got burned at the stake for it, I shall wait awhile until my wounds heal over to upgrade :)
Armando
zildjian
zildjian
Actually, the 3806 also supports editing of displayed source names; I don't know about the 3805.
G
genesis471
Miamienesex said:
Best Buy now sells higher end equipment thru their "Magnoilia" section located inside most of their stores.
Armando
Wow. I was not aware of that! Thanks for the update!
Mike
