Hi JKnPA:
A VERY reasonable question. The Sony is indeed a good system, although it is lacking any additional inputs and/or outputs for integration with other components.
As you probably know, in a motorhome, space is hard to come by. There is a limited amount of space that I can add AV components to an existing enclosure that already exists. We have already added a number of misc components (satellite receiver, Verizon Broadband router, WiFi router, music bridge, etc) and are close to maxing out the space, not to mention the heat geneated by these gizmos may become a consideration. We still have another item or two that we want to add, one of which is a DVD recorder. The Panasonic unit comes with an integrated DVD recorder and as such also a TV tuner which the Sony does not. It also has additional inputs and outputs for other components where the Sony has no additional I/Os- it has one effectively one input and one output, which is already reserved for use bythe TV as it is currently wired. So using the Sony it becomes a challenge to incorporate the music bridge. Also, the Panasonic has a front input panel including a digital input for converting movies from our movie camera directly to DVD. The Sony has topmounted control buttons which with the way that this setup was designed is simply a MESS -- you can't see what you are pressing so you in effect HAVE to use the remote. I'm 6' and STILL can't see them (even WITH my glasses!
) Next, all of the other AV components (TV's, other DVD player in the bedroom, etc) are Panasonic and it would be nice to just have one remote rather than 3-4 with the acquistition of a new DVD recorder.
I hope that you haven't fallen asleep by now while reading all of this. Probably no single reason could justify the change, but in bulk, at least to me, it is worth considering, although without a viable workaround to the ohms and powering issue, I may have to pout my way back to Circuit City to return it.
I appreciate having the opportunity to type out all my reasons; somehow it was theraputic.
So that's the story. Still in a quandry as to what to do, although I must admit that some of the terms and the math is starting to come back to me with Ampdog's reply. Not enough yet, though, to go it alone. Forums are simply wonderful for reminding myself how much I do not know and/or have forgotten.
It's a healthy and sometimes humbling experience and I am always grateful for those who take time out of their lives to help.
Thanks for your post. I feel much better now.
- SD
