Not exactly
I am a sniper...
What we need to know is a little bit about your speakers. You want to set the receiver to something that gives them the ability to handle their full range without going so low that you create a dip between them and the sub, while also not making them so high that the subs start to perform outside of their range either (too high). Running the sub channel higher can make it more easily localized (you can tell where the sound is coming from). Are these Infinitys like TSS type models that are smaller or are they mid-size bookshelf speakers? If they are the smaller sattelites, I'd say 100Hz is probably right for them. If bookshelf speakers, 80Hz might work better.[/QUOT
Hey!!! I see your back
They are the smaller satellites. I figured for satellites they should be set at 100Hz. I just wanted to make sure. I turned it back up to 180Hz and set the gain to 6. You can really fine tune it by ear if you listen to the music soundtrack. When it gets a little too much bass with some humm to it you know you went to far.
I know its not perfect like using the spl meter...but it's close. I'll get one sometime soon. The subwoofer level on the receiver is where it gets tricky. I really do need a spl meter.
