Hello all, I'm brand new at setting up a home theater, but I'm hoping that after much browsing here and on other sites that I know enough to ask the right questions here before trying to assemble a system.
I currently have the following components:
Receiver: Yamaha RX-673
In-Ceiling Speakers: 4 Definitive Technology 5.5r
Sub: BIC V1220
I will be purchasing the following speakers in the next couple days from somebody used via Craigslist:
Front Left & Right: 2 BIC DV62si
Center:DV53CLR
My questions are:
1) Because of an entertainment center that does not have shelves, I'm either going to have to ceiling mount the front left, right, and the center on a 10 foot tall ceiling or place them on top of the 6 foot, 9 inch tall entertainment center where I can build mounts to angle them downward. Which is the best option? The house was pre wired for ceiling speakers, so there wouldn't be any extra work to mount them there.
2) Will the Definitive Technology speakers work ok for surround left, right, and back as ceiling mount? (Again, on a 10 foot tall ceiling)
3) Should I consider going with the BIC DV62CLR instead of the smaller 53CLR? I can't find many recommendations for the 53CLR, but there are a decent amount for the 62CLR.
4) Lastly, and maybe most importantly, does this system work together well? Anything that's blaringly inadequate or lacking? Speakers that don't match together well?
Some info about the room: As mentioned, it has 10 foot ceilings, the design is an open floor plan with a kitchen to the back of the living room and another room to the left when facing front that would provide no real boundary to the rest of the hose. Living room rough dimensions are 17 deep and 15 feet wide. Depth into the kitchen would make it approximately 27 feet deep and the width with the other room until a lowered soffit would become about 19 feet. Living room flooring is carpeting surrounded by ceramic tile over cement foundation. Right wall when facing front is an outdoor wall and front wall is an interior wall.
Thank you very much for looking, any and all advice is welcomed. Please let me know if I need to provide more info or specs for the components.
Chad
