https://www.avsforum.com/forum/155-diy-speakers-subs/2971132-diy-sub-600-vs-hsu-vtf-2-a-2.html#/topics/2971132?page=4
I’m liking this thread. I see that um18 mentioned. I assume you guys agree it would outperform the Vtf15.2 we talked about?
Yes, I have saws and am a decent woodworker. I remodeled almost my entire house myself, and considering there were no floors and many torn down walls I think I can manage a sub box although I’ve never tried. My finish skills are probably lackluster, but ive stained a few decks, fiberglassed a few items and worked a bit of poly sealer. Never tried my hand at a veneer but I like your idea.
Thanks for all the info here fellas! I see this being a nice summer project.
A UM18 with a beefy amplifier would have some performance advantages over a VTF15h mk2, but it wouldn't be overwhelming, at least if the UM18 is in a sealed enclosure. The VTF15h mk2 uses a ported enclosure which gives it a real advantage from 16 to 40 Hz. If you want the UM18 to have major advantage over the VTF15h mk2 in ever respect, you will need to port it, and that is a more complex construction, and a much larger and very heavy subwoofer. -And you will also need to give it a heavy-duty amplifier.
Second, the UM18 is a relatively insensitive driver whereas the VTF15h mk2 uses a pretty sensitive driver. That means that a watt will go a lot further on the Hsu sub.
In continuous output, the UM18 in a 4.2 cubic foot enclosure has almost no output advantage over a VTF15h mk2, even with an insanely powerful amplifier. They are nearly the same across frequencies from 16 Hz to 200 Hz. That is actually pretty good for the UM18 though, considering it is a sealed subwoofer. In burst output, the VTF15h mk2 has an advantage from 16 Hz to 31 Hz. Above that, the UM18
can play louder, but you do need a really beefy amp to do so. We are talking like 2 kW+. One advantage that the UM18 has is that it will have some output below 16 Hz, where the VTF15h mk2 will have very little. The problem with that is you would need multiple UM18s to get audible output at those infrasonic frequencies.
The people in that AVS thread just assuming that the UM18 will flat out outperform the VTF15h mk2 are really under-estimating the engineering that went into the VTF15h mk2.
