flamingeye
flamingeye
Hello I`m pretty new to this hdmi thing I have a yamaha dvd-c950 it says it`s hdmi is type Ax1 I have never herd of that one before what gives
Davemcc
Davemcc
I'm going to guess that refers to a standard HDMI type A 19 pin HDMI connector times 1 output. Just a guess, however.
flamingeye
flamingeye
Thank you for the reply I`m going to upgrade and I was hopping I didn`t have to do the same for dvd to get digital multi-chan through hdmi for sacd but it looks like I`m going to have to thanks again
Alamar
Alamar
I haven't checked the specs myself but have you called yamaha [or did other research] to verify that their unit won't do what you want??
Edit: I'm not sure which HDMI version they're using. However the unit does claim at least basic SACD support. Yammy DVD-C950
Davemcc
Davemcc
I can't find any indication that this is a newer version of HDMI. The Crutchfield site does say that the analog outputs must be used for SACD.
What kind of upgrade are you considering?
flamingeye
flamingeye
I`m thinking of upgrade to yamaha c961 it says it will do sacd thru hdmi and I did finally find my manual for the c950 and it wont do sacd thru hdmi only thru analog thanks for all the help!!
Davemcc
Davemcc
You will likely find your trouble on the other end of the cable. You will need a reciever that is at least HDMI v.1.2 in order to recieve and process SACD over HDMI. That's kinda why I was curious about your upgrade plans. If you are not looking to get a receiver with updated HDMI, you are better off just keeping the player you have and using the multi-channel.
flamingeye
flamingeye
Ya I figured I have yamaha rx-v1600 & every fu years I sem to have to upgrade thats y I`m going to get the new emotiva pre/pro and amp when it comes out next year so upgrading will be little easier & wife don`t freak so much thanks for the input
Alamar
Alamar
I don't intend to argue with you [I don't know enough!!] ... but why would HDMI 1.2 be required? If there was a player that could decode SACD to the proper PCM digital stream that would only require HDMI 1.1 .... right?
Sorry I'm a newb and I'm trying to learn about this stuff :)
flamingeye
flamingeye
hdmi 1.1 will only do dvd-audio you need 1.2 for sacd over hdmi thats what the spec say
Alamar
Alamar
Correct. It's all in the spec.
If the player converted the audio to a PCM stream so nothing else had to do decoding why would you need HDMI 1.2? Doesn't HDMI 1.1 allow you to pass PCM streams [even multi-channel streams]?? Is there something that I don't know about SACD that makes it special to where the player can't decode the audio stream to PCM to pass to the receiver via HDMI 1.1???
Or is this one of those things that there aren't any players that will do this so in reality you simply need HDMI 1.2?
I will try to do some googling to educate myself but responses here would of course be appreciated.
EDIT: Update ... OK I guess that SACD uses a 1 bit data format at a huge sampling rate and I also guess that this doesn't translate into 16 bit PCM with a reasonable sampling rate easily. It sounds like it would be best [considering possible multi-channel SACD issues] to let the receiver do the decoding of the signal.
I officially stand corrected ... unless the above correction is wrong :)
flamingeye
flamingeye
I have found out if the receiver doesn`t have 1.2 hdmi it will not pass it on through they both have to have 1.2 for sacd because ether or will not have the capability to send sacd through hdmi wy because of the powers abe
