<font color='#000000'>That was a record 4 posts! cantonlust, you current hold the all time record of 4 posts before realizing that this forum does a funny conversion on that particular manufacturer's name...
hehe
nnazus: take the cover off of that manufacturer's speaker and you will notice that they want to provide you with surround sound using only 4 (tiny) paper cones and a very small paper cone subwoofer. I wouldn't recommend this as it is physically imposible for those speakers to reproduce many of the frequencies present in the source audio signal, let alone reproduce them well.
For your budget there are a ton of options, but you may want to check out
Axiom Audio's Epic Micro System. Mention Audioholics and you'll get a discount. There's a 30 day money back on those systems so you can try them for free...
Don't just buy on our recommendation, though. Take a listen yourself to as many systems as you can in your price range. If possible, however, try to get a system that at least has a fighting chance of reproducing the sound found on the DVDs you'll be watching.
Lots of people like the booze sound, and that's OK - but after they compare with other systems, they may find out that they are really missing out on a lot of the source material.
Enjoy your search - this is a fun time!
[Edit: spelling
]</font>
