New speakers for my nightclub remodel
jharrison
I own a small bar, and am getting ready for a remodel. I am looking for some suggestions for some new PA speakers. They are replacing an old set of Bose 901.
Here is our current setup:
PV-VSX crossover
PV-4c amp (for sub)
Yamaha SW.1181V Sub
Yamaha p-2160 amp (for speakers)
So the amp is 80w x 2 I believe.
What are your suggestions? My budget is around $1000, so let's hear it.
jharrison
Oh, and one of the requirement is durability as it is kind of a tough environmnt. I would rather have a tank that sounds ok over a delicate speaker that sounds awesome!
BoB/335
This would probably be best asked at a PA forum.
http://disc.yourwebapps.com/Indices/22769.html
I would recommend you stay with the Yamaha Club Series or a Peavey cabinet. 1-12" with a horn. Either one of those will be way better than a home audio speaker for a bar.
I checked the specs for your amps. I would also sell the Yamaha amp and use the PV for your mains and get a more powerful amp for your sub. Cleaner sound is more pleasant to listen to and if you decide to crank it up a bit, your amps won't clip and blow your speakers. 80 watts X 2 is a lightweight for your situation. You can do all of this within your budget.
MidnightSensi
MidnightSensi
You do live music? DJ's? Recorded music? How big is the room? Type of music? Budget?
jharrison
Just recorded music from a DJ, everything from country to hiphop. The room is small, probably only around 12 sq. ft. Looking to come in under $1000.
jharrison
Yeah, I know the amp is small, but it is such a small room that it works fine. We never max it out. We already get complaint from the adjoining hotel for the loud noise.
jharrison
Craigv....
Any reason for suggesting powered speakers, even though I have an amp? Maybe just for a bit extra power?
Padge1
I'm guessing you mean a 12' X 12' room. 12 sq. ft would be 3' X 4'. Even so, that is a small room.
MidnightSensi
MidnightSensi
For under 1,000 its difficult to recommend a nightclub system, or call a system a nightclub system.
If this is a bar and you need to keep the noise level down, but still want some dynamic sound, I'd probably just use the 8" JBL Professional Control series speakers.
Two of these JBL Control 28s:
http://www.fullcompass.com/product/286360.html
A dbX DriveRack PA:
http://www.bhphotovideo.com/c/product/261160-REG/dbx_PA_DriveRack_PA_Multi_Dynamics.html
(This has a built in crossover, limiter, EQ, compressor, sub-harmonic synth, and for 100 bucks extra an RTA mic, really nice unit. Since your going to keep your levels down because of the neighbors, you can use the sub-harmonic synth to give your sound a bit more dynamics and depth).
For power I'd pickup a Crest Audio CC1800. It's more power than you need, but if you want to add another pair of speakers when budgeting allows you'll need something 4-ohm stable (two Control 28s at 8-ohms in series would be 4-ohms).
By the time you add in cables and everything your over budget, but you could buy the speakers first, then the amp, then the processor. Really with a DJ playing you need the processor though, especially on a small system like that because otherwise they will run you out of headroom before the night even gets going.
You really need subs too when budget allows, but, if you have neighbors, that can be difficult. Horns work better for directionality, playing with placement to keep the bass on the dancefloor rather than all around the room and into your neighbors, figure out where the building tends to shake and add notch filters... we can figure all that out when you get to it though.
the 12x12 must be a typo for a nightclub, because, my office is bigger than 12x12.
Lemme know if you have any questions,
Hipnotic4
Hipnotic4
i think my room is bigger than your night club..I would look into some outdoor speakers from polk, JBL or evem thespeakercompany..and then just get a nice dedicated sub, to balance the sound..
I cant imagine a nightclub system in a room that small..
jharrison
A dbX DriveRack PA:
I have a crossover, 2 PAs, an 18" sub already.... just looking for speakers.
Padge1
Sh*t... I meant 1200 sq. ft. Sorry!
I recently watched Anthony Bourdain traveling through Japan, and he hit some very small Japanese bars. I thought you may have been inspired! :D The JBL Control 28s might be a nice choice.
MidnightSensi
MidnightSensi
Maybe it would help if I actually read the post haha, sorry about that.
I'd still go for the Crest 1800, Driverack PA and the JBLs. You could put two JBLs in line on both channels (so four hanging over the dancefloor), then the sub where it gives the most impact on the dancefloor and the least elsewhere. The Driverack you can use as the crossover, and also to set your limiters and keep DJs from overdriving things, and also use the parametric EQ to set notch filters where the room resonates to help keep neighbors happier while still keeping your volume up.
jharrison
Talked with the rep from fullcompass. He says those speakers will be a good fit. And a deal at $440 shipped with the mounting brackets added in.
BoB/335
I disagree with most of the advice given here. I happen to have a really great PA system. I play guitar all my life and have been in many bands.
A Driverack PA would be a good addition but since you already have a crossover I'm not sure I would recommend that expense at this time. Most speakers blow from UNderpowering them and then pushing the volume too loud. I suggesdted more power NOT for more volume but for CLEAN sound with less distortion at even moderate volume. It just makes for a more pleasant sound and LESS fatiguing on the ears which will keep people at your establishment LONGER.
Do NOT get a 2-15" cab since you already have a sub. Sell the low powered amp. Get either the Yamaha Club series (over the JBL JRX) or a Peavey cab with 1-15" and a horn and get a more powerful amp for the sub. Check for a used QSC RMX amp. Very dependable!
And check in with the guys at Scott's PA Tutorial at the link I posted. These guys deal in all sizes of this equipment all the time.
BoB/335
Example:
QSC RMX 850 New! $369 Free Shipping $150 Rebate ENDS TODAY!!!!!!
530-600 watts at 8ohms bridged (powering 1 sub)
Yamaha Club V-15's $700 shipped Pair
Total: $1069 - $150 Rebate (ends TONIGHT!) = $919 without selling that amp.
I'm telling you with 250 watts per channel to the mains and 600 watts to
1-18" sub, you will have a very fine system worthy of a DJ and Karaoke and this will sound great at any volume in that room!
