I'm with lovinthehd.
However, if money is tight (as you just bought a new house) and you have an intent to really get into a decent Home Theater Setup, then you could go at this a bit bass ackwards. Give us the Room Dimensions (LxWxH) first and advise how much you could afford (some time later) to replace the Sony Speakers, and give us the present budget budget for a Sub and Receiver; then we could help guide you forward. The replacement budget for the speakers will help us fit the Sub and Receiver to them.
I hope this is helpful.
This is in the basement, roughly 18' x 22' from the listing specs. The viewing area is tighter as the speakers are wall mounted around the seating area (I'll get a measurements and report back). Budget is super tight right now, main goal is to get sound up. I do plan to invest in a substantial setup in the future but I'd like to get a better understanding of what I should go for.
I am nervous to start with a higher end receiver in case the 3ohm speakers blow it up (valid concern?)!
My short term options are,
a) pickup a Sony STR-DE898 or JVC RX-5020V from the local pawn store for ~$50 and test these speakers out. Not even sure if they work. Or
b) Bring my Samsung HT-C550 down from upstairs and use that full system instead. Currently only using 2.1 upstairs. The slight problem with option B is I would then need to get a soundbar or similar for the aristocracy upstairs.
Secondary question; the wiring that runs through the basement walls has no markings for + and/or -. As I cannot trace each wire end to end, is there a way to correctly hook up the speakers?
Apologies for my tardy response, I actually did not know anyone even replied to my post! I am just getting used to this site. I am so pleased you all took a moment to share your wisdom -- thank you so much for the advice thus far, much appreciated!
