Help us help you. Does the player have an integrated amp, or preamp, or it outputs Phono signal? How do you connect it, to what, using what type of connectors, in which type of input? Hope this makes sense.
One fairly typical setup is:
- record player has a PHONO output (RCA cable or RCA connectors), be aware that’s not LINE level output that you can connect directly into an amplifier via RCA.
- Phono preamplifier, which takes PHONO signal, applies an RIAA frequency correction and amplifies it to the LINE level (PHONO level is too low for a regular amp to handle). Some record players have Phono preamplifiers included, and have either a LINE level output, or have both LINE and PHONO outputs. If that’s the case, the LINE output can be connected with a regular input of an amplifier.
- amplifier. Some include an input for Phono, which does both the RIAA correction and signal amplification to Line level.
Hope this helps.
