New Media Center PC
sholling
sholling
I've already posted the file/media server so here is the media center PC/media player that's going in my family room. To be totally honest I've had a media center PC before but gave up on the concept because the tech and need just wasn't there and the WDTV live just did almost everything better and easier. Times have since changed and the tech is better and with 24bit audio I have a need.
First up the design goals:
  • Near instant start up.
  • Snappy response.
  • Acceptable interface.
  • Online content
  • BD rip playback in full 1080P with full lossless audio support.
  • Low power drain
Hardware build list:
  • Sapphire Pure Fusion E350 motherboard/CPU combo. I chose this for it's fantastic feature set including ALC892 audio, Bluetooth, and the overall design. I like this board a lot.
  • 2x4GB SODIMM DDR3 1333 that I had laying around from my notebook's RAM upgrade.
  • 60GB Vertex 2 SSD as the boot drive. It caught a sale ($85). :D
  • 500GB 2.5" WD Green A/V drive. I chose this because of it's near silance and the fact that they are designed to run 24/7 for years. All swap and temp files will live here.
  • Silverstone SDP08 3.5" to 2 X 2.5"-Inch dual drive converter.
  • Thermaltake ITX HTPC case. Attractive, nice layout, well built, and no bright lights.
    I did not want the noise of an optical drive so none was installed.
Software List:
  • Windows 7 Home Premium 64bit
  • Boxee for the online content.
  • Media Monkey 3 for audio.
  • PowerDVD 11 Ultra for video.
My first impression was amazing boot times. Roughly 30 seconds from power on to ready to rock. Application launch times are near instantaneous. On the other hand even at 1080P@60hz the video is very washed out, grainy, and has a tiny bit of stutter, sort of like watching TV from outside through a screen door on a bright day. Not at all usable as is but I'll keep experimenting and maybe I can dial that out. In the meantime I'll keep using my other devices for video playback. PowerDVD also refuses to recognize my DLNA servers, but my biggest complaint is the interface. It's a huge advertisement for various videos that have nothing to do with your collection.
Boxee is still the best looking beta that I've ever seen. Sure it still needs a bit of work but I love the instant access to my favorite video podcasts. I'm addicted to Revision 3 and TWIT and for me this alone is worth the build cost. It's also playing multichannel flacs but I'm not sure if it still down-samples to 16 bit. There seem to be mixed reports that Boxee sill down-samples HD and multichannel flacs and others that say it doesn't but nothing concrete on Boxee's site. Boxee seems to take pride in not giving any detailed information or specs. Anyway I like it.
Media Monkey 3 is as always plain but reliably plays most audio formats including 24bit flacs. So far the only one that stumped it is multichannel FLAC but that should change with the next version.
I'm only one day into using this device so I still need time (weeks) to get everything dialed in.
Stock Photo Courtesy Amazon.
BoredSysAdmin
BoredSysAdmin
I have similar htpc, atom 330/ion with win 7.
I found that boxee forgets network shares if it woken from sleep mode :(
What do you use to control it?
I use usb MCE IR receiver and programmed my rf20 remote for MCE Keyboard codes which I borrowed from my old harmony remote
sholling
sholling
I mapped a drive just to be sure. I just can't get Boxee to accept my network drive for the music icon. I think the dang coders are dissing networks again. ;)
Right now I'm using a Lenovo mini keyboard but I'm going to try one of these mini keyboards with touchpad. The Lenovo works fine with everything but Boxee but for some reason it has a mind of its own in Boxee. FWIW the Lenovo is onsale for $25 with free shipping until 6/20. Coupon code USPC11JN36336. Credit to Bensbargins.net for the heads up.
I suspect that HD video is right on the ragged edge of the E350's capabilities. No big deal, I'm going to try this for a few weeks and try to dial it in but if all else fails I have the Oppo for videos. Lots of choices. :D Either way it was cheaper to build the new media PC than it would have been to update my old and long retired Core 2 Duo based media center.
sholling
sholling
Update: I'm getting PowerDVD dialed in and it's much better. What I had to do was adjust video brightness and contrast in the Catalyst control center and enough to get rid of the washed out look and the picture is much better now. The cost was readability of windows screens but I can live with that. I also think I have PowerDVD passing undecoded DTS-HD and Dolby TrueHD to my receiver. It still skips now and then but it's pretty usable although the color still isn't as good as the WDTV live. I'll keep working on getting it dialed in.
BoredSysAdmin
BoredSysAdmin
Update: I'm getting PowerDVD dialed in and it's much better. What I had to do was adjust the on board video's brightness and contrast and enough to get rid of the washed out look but the picture is much better now. The cost was readability of windows screens but I can live with that.
I feel like I'm reading my own diary.. I went thru exactly same issues...
There must be something we both missing...
sholling
sholling
Update, the remote on the right is a joke. The RF dongle has to be on the front of the PC and the range of the remote is about 3-5' if nothing is in the way. I'll work for my server because I'll be 3' when setting up anything and the keyboard itself is nice but the range is way too short. The Lenovo's trackball is sloppy but but it works fine at 20 feet.
BoredSysAdmin
BoredSysAdmin
Is this is same one? Looks very similar
http://www.techpowerup.com/147529/Chill-Innovation-Announces-New-Wireless-Micro-Keyboard.html
sholling
sholling
Similar but not the same. Perhaps a variation from the same factory in China? The one that I have has page-up/page-down and arrow keys below the touch pad. It also has a laser pointer. It's also available as RF or BT. I chose RF which seems to have a range of 3-5 feet line of sight to the dongle.
The chill is really close but no arrow keys below the pad and it has a flashlight.
The concept is great but the execution sucks. But maybe I just got a bad one.
sholling
sholling
The HTPC keyboard I've been wanting finally went on sale ($80 for dented box though 6/24/11) so I ordered a Logitech DiNovo, but I'm also liking the Unified Remote Android App.
The boost to 8GB of RAM with 2GB dedicated to video cured the color and responsiveness issues and I'm finally happy with my HTPC. It's replaced my WDTV Live in the entertainment center. I may add the WDTV Live back later for its ability to play ISOs but I'm out of HDMI ports and really don't miss it enough to install a switch and can always use Virtual Clone Drive to mount an ISO as a virtual disc.
The only thing I miss is controlling absolutely everything in the entertainment center with my Harmony remote but I have an idea how I might make that work to. :D
Final software lineup:
  • Boxee for online content (free)
  • Foobar for music playback including 24bit and multichannel flacs (free)
  • PowerDVD Ultra for video playback
  • Virtual Clone Drive for mounting ISOs (free)
  • Unified Remote for Android PC-Client (free or $4 - mostly rocks!)
  • ESET NOD32 antivirus
