Welcome to the forum, Shane!
What is your budget for a new receiver? A "bank load of money" means different things to different people.
As for your speakers, their efficiency rating is decently high at 91 dB. My NHTs are rated at 85 dB, and receivers like the Onkyo TX-NR626, Denon AVR-E400, and Denon AVR-S900 can play them very loudly (to me) with no discernible distortion of lack of dynamics. That have ratings in the 90-95W range for an 8-ohm load from 20-20k Hz at small total harmonic distortion. Ratings in the 80W or 90W range are going to be similar in performance if the rest of the amp is designed the same. An ability to handle short duration, high power peaks (e.g. from cymbal crashes) is important to maintain accuracy at higher volume levels, and the amps that I mentioned are recent models that I've used that do that. I think that has a lot to do with the capacitors, but others here can chime in if I'm wrong about that.
For every 10 dB of volume increase (viewed by some as being twice as loud), you need 10 times the power. A lot of times, you're using under 1 W to power your speakers. To get twice as loud as 80 W, though, you'd need 800 W.
