New firmware update Panny BD35
mtbound10
I have a BD30 which I think also takes firmware updates... are they difficult to update?
G
gwhiz
The player is easy to update if the down loaded file from Panasonic is any good.
I tried to download their file 3 times and it all but wiped out any software loaded on my BD 35. I finally called Panny and they mailed me their CD.
Worked great you just pop it in and the player does all the work.
jostenmeat
Nah. The first time I did it, I was having issues, but I don't know why. Since, no problemo. I think I've been using Roxio to burn on the CD-R. Once you load it, I think it's maybe 10 minutes, actually... probably less than that.
Here is the Panasonic BD30 FW support thread. jsmiddleton4 is the most avid researcher/supporter there it seems.
http://www.avsforum.com/avs-vb/showthread.php?t=1064552&page=18
Here is the official DL site for the BD30, and I went to North America as an attempt towards your convenience. If you live in Bangladesh, sorry.
http://panasonic.jp/support/global/cs/bd/download/bd30/bd30_na.html
mtbound10
I just downloaded and copied my firmware upgrade and the damn CD-R disc is "not compatible"...
what the fizzle!
mtbound10
I figured it out. There was no indication that the downloaded file needed to be opened and or unzipped!
She's updated!
bandphan
bandphan
If I've connected my player via a LAN cable to my router would this bypass the need to burn a cd and what does this update actually resolve?
Thanks, Bill:)
Ivè never tried thru a LAN. Update is to fix Audio sync issues and over all speed.
billy p
billy p
Just received my cat 6 network cable from monoprice and plugged it into my router, set up the player and it installed the 1.8 firmware flawlessly. Thank God, no more CD coaster...:eek::)
bandphan
bandphan
Fwiw making Network or any other cables requires a small, very small invevestment and no need to purchase agian. Pinouts are simple and easy.
