Hi,
I've recently been playing around with using a Surface pro as a dedicated music server, and i'm liking it so far. However, I'm interested in a DAC...I have a bunch of noob questions though, i'm hoping you can help me.
Here's is setup:
Surface pro connected to denon 1913 avr through mini display port to hdmi. Denon feeding 7.1 klipsch reference II speakers, sub is jamo sub 650 (I only listen to 2.0 for music). Using Foobar2000 on the surface, and controlling it with tablet/phone. The setup sounds nice, but of course it could probably be better.
Questions:
It's my understanding that most component dacs typically connect to an amp / receiver via red/white analog cables? Would that be better than how I have it setup through hdmi?
Is it ok to use the denon avr with the dac? Or should I look into buying a separate amp to power the 2.0 speakers.
If I bought an amp, would it be ok to run speaker wire to my main left and right channel speakers, and keep them connected to the denon as well? basically having them connected at all time to both the receiver and the amp.
