B Bigdogk5 Audiophyte May 2, 2021 2 0 1 61 May 2, 2021 #21 TLS Guy said: Those will not work at all. There is no way they could crossover at 800 Hz, you would blow them right away. There is one of yours, but you can see from the photograph it is in tough shape. Click to expand... This is absolutely incorrect..those earlier 2 inch domes ironically are crossed over at a lower point than the kappa...usually at 5 and 600hz..kappas cross at 800...so 2-300 hz higher..ive been using those 2 inch domes for 2 years no problem Attachments Screenshot_20210406-160343_Gallery.jpg 854.5 KB · Views: 356
B Bigdogk5 Audiophyte May 2, 2021 2 0 1 61 May 2, 2021 #22 raprice3 said: Thanks for your thoughtful response. I really appreciate it. I saw a couple of posts on ebay for infinity polydome midranges, but they are apparently for different speakers. Would they work for the Kappas? If not, I will probably just get some new speakers. Thanks http://cgi.ebay.com/PAIR-OF-INFINIT...mQQptZSpeakers_Subwoofers?hash=item5ad55b4fd9 http://cgi.ebay.com/PAIR-INFINITY-P...ptZVintage_Electronics_R2?hash=item4cec7f76b9 Click to expand... I just noticed how old this post is..but yes they work..ive been using for 2 yrs while searching for original polys to rebuild....just in case you boxed the speakers up and put them away and still have..they work and sound good Attachments Screenshot_20210406-160343_Gallery.jpg 854.5 KB · Views: 364
