I need to hook up my Xbox 360 wireless. What do I need to buy?
GlocksRock Audioholic Spartan Aug 22, 2006 #2 The wireless adapter that is made for it, or something similar.
J jmy350z Enthusiast Aug 22, 2006 #3 So I just need to buy the wireless adapter? I do not have to buy a router?
GlocksRock Audioholic Spartan Aug 22, 2006 #4 well yes, the wireless adapter needs to communicate with some other wireless device, so you will need a wireless router hooked up to your PC as well.
majorloser Moderator Aug 22, 2006 #5 If the Xbox is the only thing connected to that network, I believe they also offer a wireless bridge you can hook up to the cable/DSL modem. Otherwise you need to set up a wireless 802.11 network.
