mazersteven
mazersteven
Right here. If you want a sub that will perform better then the x-sub, but don't want to spend a lot.
Dayton SUB-120 12" 150 Watt Powered Subwoofer
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=300-635
Or what I recommend it if you can save a couple of hundred more you will get much better performance for your room. I waited over 1 year before I purchased my subwoofer. Patience.
jar
Where would I check for B stock on those items? on the stf-1 it said 120/240v , 120v is standard for US and Canada is that what that is? do I need to be concerned about cross over and the HZ dont have a clue what that means but I keep seeing it.
rnatalli
Forgot about the Dayton. Won't be as musically as the x-sub or HSU, but will certainly fill the room.
mazersteven
mazersteven
IMO he will not even hear that x-sub. It will be like a fart in the wind. :eek:
jar
I just checked out the Dayton sub, they also have live help which is cool and I liked the price, I'm thinking I might go with them, thanks again for your help very much appreciated.
jar
a fart in the wind lol to funny :D thanks again guys for your help oh and by the way I'm not a he lol!!!!!!:)
Seth=L
Seth=L
Hey Seth what do you mean put it together???? you mean home made?
Did you click the link? You have to put the woofer and amplifier inside the box, all materials are included, the box is premade. All you need is a screw gun or screw driver.;)
For your money, that subwoofer is really your best bet. If you can afford the partsexpress 15" subwoofer, then go for it. It's only $300. The X-sub and HSU STF-1 are 8" subwoofers, they won't have anywhere near the output of that 15" subwoofer.
jar
Just ordered the dayton sub 12" 150 watt $148.00 and then the cable to go with it and then I will have to deal with customs etc, probably another 40.00
Thanks again, I will let you guys know what I think of it.:)
