Need some advice....
G
Grey Ghost
Guys,
I have only one line conditioner being a Monster Cable 2500. I have both my B&K ref series amps going through it total watts is 1250. I have my Ref 50, 46" TV and my DVD player going through it also. Is this too much to ask from the Monster Cable 2500? I also have a Velodyne SPL-1200 series 2 but she is just plugged into the wall. How would you guys have this running and what product would you use? Please reply this is bothering me, thinking my system is lacking in ample power supplied to each of my components.
Thanks,
Craig Elder the Grey Ghost :p
joelincoln
First, I'd say that as long as you're not blowing the Monster's breaker, then you're not over-taxing it. It is rated for a max of 1800 watts.
Second, the units that you have protected are the most important. It would be nice it you could protect the sub also, but the TV and amps are more important IMO.
Assuming that you live in an area that has no significant power problems, then I'd simply buy a good surge protector for the sub to protect its amp.
