So, I got the following setup -
Denon x3700h AVR
Focal Aria 926 Floorstanding Speakers
Focal 900CC Center Speaker
I wish to add a sub and satellites to the mix.
The usage is - 70% music, 30% movies/games.
Room is about 3.5m in width and 8m in length. Since I live in an apartment building, I don't believe I'll be using high volume all that much.
For the sub, it's important for me to have great integration, somewhat of a dissappearing sub, much like REL offers, only with a lower price tag but it should also have a kick to it for movies.
Currently, I'm looking at the SVS SB1000 Pro as it has both a great phone app for remote control and a high level input.
I've also considered the REL HT/1205 which should be great for music as well as cinema only without an app and the high level input.
If you have additional recommendation for a 500$-ish sub that you think is great for both music and cinema, quick, minimal distortion and accurate with enough kick, let me know.
For the satellite, I'm really confused since any bookshelf speaker can be used for rear surround speakers.
Sometimes, due to the size and design, smaller much less capable speakers cost double of great bookshelf speakers that are larger.
I would love to have a bipolar rear speakers as my couch is at the wall (3.5 width as mentioned) but regular bookshelfs are also an option.
I saw the following options -
Polk Audio ES20 (bigger than regular satellites and seem to have a great range and I just looooove their design and look)
SVS Prime Satellites - saw mixed reviews for those and their price is like 100-200$ more than the polk
Fluance Signature (BiPolar) - Cheapest option I've seen for bipolar, seem to get good reviews, need more of a hands on opinion if anyone tried those.
Klipsch 250S BiPolar - big, heavy with some good reviews, need your opinion on those.
Saw recommendations for B&W M1 - Are they worth the price?
Thanks in advance for any feedback/recommendations!
Cheers!
