Best you can likely do is a pair of powered PA monitors, and that may or may not work well with the analog outputs from the br player. Something from Behringer perhaps. Might increase your budget by going diy on the screen with some 2x4s and a king sheet or something similar....friend of mine did that for his backyard viewing, worked well enough and is about as inexpensive as you can get screen-wise....
