Need knowledgeable input...
X
Xan3791
I put together a home theater system 6 years back that I still use. The amp/receiver I picked was the Yamaha DSP-A1. It was their flagship model and was very highly thought of. The only issue it has is that it lacks support for component (or better) video inputs/outputs (uses s-video).
This wasn't a problem before since I just ran the dvd player video straight to the TV. However, it is about to become an issue once I upgrade to a plasma/hdtv monitor. I will now have multiple component (or better) video outputs that will need to reach the monitor.
The obvious solution is to buy a new amp/receiver, but spending $3500+ on a new receiver/amp really isn't an option anymore since I'm a family man now. The plasma was a hard enough sell and that was accepted because I can get it at cost and it's easy to see the benefits to it. A receiver/amp, unfortunately, just looks like a box to most people.
It's been a while since I was up-to-date on Home Theater, but I'm making the assumption that a 6 year old DSP-A1 would still be better than a new ~$1000 model (other than the upgraded inputs/outputs).
If that is not the case, please correct me and, if you care to, give me a bit of an explanation as to why it's not true.
If that is the case, I would really appreciate hearing some opinions about what options I may have from people who have stayed much more in touch with recent happenings in this field than I have. I was thinking that I might be able to run all the video outputs to a remote-controlled switching station that connects to the monitor. This would mean I couldn't use HDMI (which the monitor can support), but that's not that important to me at the moment.
Any help or time given to this would be very much appreciated!
F
fergusonv
You may want to look into something like a "DVDO iScan HD+ Plus HDTV Video Scaling Processor" for your video needs. The VP30 can do HDMI switching...
Rocky
Rocky
i would look at the above posters suggestion, but yamaha makes some pretty nice receivers for the $1000 range. id take a look at the RX-V2600 specifically.
jcPanny
jcPanny
What is your speaker and room setup?
The specs on your speakers will give us an idea if a $1k receiver will have enough power for your HT system.
jaxvon
jaxvon
I believe your Receiver has a 12v trigger out. If it does, then you can just use an external switcher to do the work.
X
Xan3791
Thanks very much for the info so far. Sounds like the switching idea might deserve more thought on my part. It would be nice to be able to use HDMI so I'll be looking into switchers that can convert up to HDMI.
Still open to any and all other suggestions, if anyone has any. :)
The speakers I use are all Monitor Audio.
Fronts: PMC 702's
Center: CC700
Surrounds: MA FX2
Sub: ASW 110 x2 (wanted the crisper sound of the 110 for music, while still being able to push around enough bass for movies.)
The room is still to be decided. We're moving in about 3 months, but I'll be picking a place with a room that will meet the needs of my system.
Bryce_H
Bryce_H
Just to give you a perspective I just upgraded from a Yamaha DSP-A3090 (the flagship several years before yours) to a Denon 3805. Mostly for the reasons you mentioned, but also to get the additional processing options (DTS and 7.1). The unit is in my dedicated HT in the basement and powers 5 Def Tech speakers (hopefully, soon to be 7). The Yamaha may go in the living room once I get the speakers. Just some thoughts. Also upgraded my DVD player from a Sony DVP-S7000 to a Pioneer.
