Recently replaced my jvc rx-6500 rcvr with the onkyo sr602 and have spent the past week sitting in my recliner with the auto set microphone on top of my head trying to get it to read my sub. I'm a newbie, obviously. Fond the review on cnet (and others about the issues with auto set on this unit and did what they said the onkyo rep told them. Turned the volume al the way up on the sub and it read it. However, it now said the sub was too close. It's 3 ft from the rcvr. All the stuff I have read recommends setting it up manually. Which I would love to be able to so I can learn how it all works. Hers what I am working with. The oom is 16x17 w 8' wood ceilings. Walls are sheetrock. Floor is 1/2" ceramic tile, no carpet. Two recliners and a futon and a 60 gal fish tank is all thats in the room other than Theater.
Front and back speakers are mounted in the corners of the room and all four are polk rm2350 and register small on configuration. Front are both 15' from listening location. Back are both 8' from listening location. Center is a klipscg sc1 and is 11 '. Both surrounds are Klipsch ss1 and are 9'. Sub is a klipsch KSW 12 and is 12' from listening location, in corner under front left. The area I am having problems with is figuring out the calibration and especially the EQ. I've been told that the calibration is mostly what sounds best to you and that it's best to have the tones at about the same level from al the speakers when you test. true or not? I don't understand the eq at all. The settings available are (in order for all the speakers) 80hz, 250hz, 800hz, 2.5khz and 8khz. I'm assuming this is for bass, trebl and midrange, but I don't know what is what in relation to the numbers. Should all the speakers be set the same and is there a starting point? The sub is 40hz, 80hz and 160hz. I really need some help here and would appreciate anthing. Even a good starting point and some advice on how to make it sound decent. I have also been told that if I set it manually I will have to reset it for different movies depending on the soundtrack of the movie. Is that true or can I just set it and leave it alone and have it sound good? The tv is a mitsibushi 52725 52" HD and the dvd recorder is a panasonic DMR-E55, CD is JVC XL-MC334, and Dish HD mpeg 2. Not gonna upgrade the dish until they have enough HD to make it worthwhile. The DVD-R and CD is not hooked up yet. Why bother until I get the sound right. All hookups will be digital. Dish is HDMI with optical to the receiver. DVD-R will be component an optical. Hopefully I have given enough detail for somebody with more functioning brain tissue that me to be able to give me some help. Thanks and have a good day.
