Ok, so am doing some renos in the basement and have essentially torn the place down to the framing...before drywalling it all I figured I'd run some in-wall sound cables to clean up the place for a 5.1 setup (small basement 18x12 feet).
What are my options? I'm being told I should go with an amp and run the speakers off that, easy breezy...however, the whole idea of going with a HTPC was to have just one box, get rid of the DVD, cable box, amp etc...so I'd like to avoid the amp if possible (atleast for now as it's not in budget). The only other HTPC option I've been told is a standard 5.1 computer speakers set up (which I happen to have a spare of) that runs to the sub and then to the comp. Low quality but I avoid the amp that way.
Now I need advise, I've picked up 16awg speaker wires to run to the four corners of the room for the 5.1 setup and now I'm just wondering if I should splice in the computer speakers for now and later go with a decent set of speakers and amp, maybe troll the classifieds and wait for a good used one to come up.
So to sum up:
1) Is the 16awg speaker wire the appropriate stuff to be running through the walls for a future 5.1 surround sound system, amp+speakers? (Nothing crazy, just a decent system)
2) Will a standard 5.1 computer speaker set up, spliced into the corners work with the 16awg? Something like this:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16836121120
3) Does this all make sense or have I been fed a load.
