Need Hockey Pucks...
Rickster71
Rickster71
Didn't know the best thread for this:
Anyone know where I can find hockey pucks cheap?
I plan on using them to brace the inside of a speaker cabinet.
The best I've found so far has been $1.25 each, but with $4.00 (each) for shipping!
Local sporting goods stores are ridiculous, and can't find any at Wal-Mart.
Thanks,
Rick
alexwakelin
Hockey pucks to brace a speaker cabinet? That sounds interesting. They are rather dense and heavy, so shipping won't be cheap, but $4.00 still seems a bit high. Do you have a Play It Again Sports in your area?
ParadigmDawg
ParadigmDawg
I bought 4 of the this weekend to try and use as sub feet but my sub wals off of them. They are free but you would have to pay shipping.
You are in NJ man, there has to be a rink around there somewhere!! Go get some used ones.
penpitt
Try a local rink or look for a hockey store.I bought 6 pucks for my son at the local rink here for $1 a piece.
ParadigmDawg
ParadigmDawg
Guess I will throw in the 4 I have with your new amp, if they will fit into the box.
Sheep
Sheep
I'm using 4 pucks to hold up a sub, and one to balance my center. They're really cheap up here though.
SheepStar
Adam
Adam
How many do you want, Rick? If you are buying a few, you could try out this link through Amazon. $1.29/puck with a flat shipping rate of $7.95 per order.
jamie2112
Rick how are you going to use them to brace the speaker? I am interested..
Rickster71
Rickster71
Hi Jamie,
I have 1/2 thick piece of All-Thread or threaded rod left over from a job.
I'm going to use a sleeve nut, and join two pieces of rod, and make a home made turnbuckle.
Then I'll drill a shallow hole in each puck, just enough to hold the all-thread in place.
Not sure yet if I'll glue the pucks to the inside of the cabinet first, or just let the pressure as I spread open the all-thread hold them in place.
Rickster71
Rickster71
Thanks to everyone that responded!
And Thanks to Alex and ParadigmDawg for their great puck offers, (or is that 'puckin' offers?):D that should be enough for this project.
Rick
