E
elet911247
I have a sony receivers.. ( its just a Home theater reciever ).. and i Just got 2 Cerwin vega speakers 15"s Floor speakers. And they r 4 Ohm speakers while my reciever is 8 ohms... It sounds ok.. but It should be louder and it should have more bass.. Does this mean i have to get a AMP.. and if so what size should i get? and How should i have the speakers hooked up.. ? Under what ? like under center or front? I have heard the speakers from the person who i bought them through and they were alot louder and more bass... he was pushing more power though.. So any help would be helpful.. thanks alot.
Adam
Adam
Welcome to the forum!
What is the model number of your Sony receiver? I ask so that I can look up some info on it.
[BTW - you should only start one thread with the same question, not two.]
E
elet911247
Hi Sorry about posting in to different forums thought it help.. and thanks for the help.. Its a Sony (Str k 502 p) is the model of the reciever. And thanks again for helping me.
Adam
Adam
Hey, no worries about the two threads - I was just letting you know. :)
How many speakers are you running off of that receiver? If those are your main speakers, then you would hook them up to the Front L and R speaker jacks.
The manual does say that the impedance range for the receiver is 8 to 16 Ohms, so running speakers that are rated at 4 Ohms poses a risk to the receiver and the speakers. I'm not sure that is why they wouldn't sound as loud. [Note: How loud they sound, and the bass that you hear/feel, is also a function of the room that they are in and where they are located in the room. If your room is a lot bigger than the room in which you first heard them, then they could certainly sound quieter and with less bass.]
Are your speakers set to "Large" or "Small"? If they are set to "Small", then the receiver isn't sending them bass below a certain frequency - so set them to "Large" and see if you get the bass that you were expecting. If you are using these with a subwoofer, then we can discuss which setting is better for you. I'm just suggesting that you set them to "Large" for now to test out the bass in your new speakers.
