How old is the Harman Kardon?
You wrote 'amplifier'- is that one piece, as in, an integrated amplifier, stereo receiver or AV receiver, or is it a preamp/power amp combination?
I agree- disconnect any input from any other device and leave it as only the amplifier and speakers. If it still hums, turn the power odd and disconnect the speakers so you can test it with headphones (earbuds will work just as well if they're able to deliver a hint of bass). You may need to get a 3.5mm to 1/4" adapter, but that's the only additional thing needed (unless you don't have ear buds).
If the hum stops when the speakers are disconnected, move the speakers and speaker wires.
If you have a subwoofer, that should have been included in the original post and in that case, disconnect it and the hum will probably stop. This means you need to use a different outlet or possibly, a wireless transmitter/receiver for the sub's signal if you can't use a different outlet.
