Using the 2807 is a viable option
Rgray,
Welcome to the forum.
SITUATION SUMMARY: Currently, you're Denon 4308 runs a 5.1 system, and one set of the receiver's amplifiers (SURR BACK L/R) is powering four other zones via Zone-2 amp assignment through an ATON speaker selector switch (Model DLA4 ?).
PROBLEM 1: You want to deliver more power to the other zones (LR, Kit, Deck, Gar).
- The other zones power is low because only one set of receiver amplifiers (SURR BACK L/R) is being divided into fourths by the ATON. Furthermore, the ATON's protection circuit (a good thing) is lowering the output power to protect the Denon from the impact of the lowest impedance of the four sets of speakers you have (2x Bose models, 1x Klipsch, and 1x in-walls) on a parallel circuit connection.
- To boost the other zones power you need more amplifiers powering the other zones, either by smartly using the 2807 (nearly free, but complicated) or getting a dedicated multi-zone amp (more expensive, but more straight forward). I will only discuss the 2807 option.
Q1. Can I utilize a Denon 2807 I have collecting dust in the basement?
ANSWER: Yes, but it is a bit complicated, and for best effect you will need to buy another ATON.
- You are fortunate since the 4308 has Zone-2 and Zone-3 pre-amp outputs (PRE-OUT) and the 2807 has pre-amp inputs (EXT. IN). This capability makes it possible to get more amplifiers powering the other zones.
- The avr-to-avr connections are as follows; connect 4308 Zone-2 L/R pre-amp outputs to the 2807 FL/FR pre-amp inputs, and the 4308 Zone-3 L/R pre-amp outputs to the 2807 SL/SR pre-amp inputs.
- 4308 set-up; see manual page 75-76 for more info on avr settings.
- The 4308 can be set to control the volume in Zone-2 and Zone-3 thus eliminating the need to control volume by manipulating the 2807's volume (set once and then forget). From page 36:
The volume can be adjusted when GUI menu “Manual Setup” –“Zone Setup” –“(select the zone)” –“Volume Level” is set to “Variable”. The volume can be increased up o the valueset at GUI menu “Manual Setup” –“Zone Setup” –“(select the zone)” –“Volume Limit”
- The 2807 will be set to the EXT IN program mode, and the 2807 FL/FR speaker terminals connected to one ATON, with the 2807 SL/SR speaker terminals connected to a second ATON.
Each ATON will then be connected to only two of the other zones speakers (i.e. one ATON to LR & Kit and other ATON to Deck & Gar).
- This configuration will more than double the available power in each of your zones.
PROBLEM 2: The 2807 and 4308 have the same remote codes and will both follow the same commands.
Q2: The 4308 has a remote ID 2, can you use this setting and have the Harmony respond correctly.
ANSWER: I do not know offhand, and recommend Googling the issue or hitting Harmony's website.
Clear as mud??
Cheers,
XEagleDriver
