I have an eiki 7070 which is a cd/cassette player from the early 2000's that doesn't take any cd's that I have burned but takes commercial cd's perfectly well. I burned a few songs on my cd-rw disk using itunes on my mac and I also tried turning the songs into wav files then burning them at a slower speed but nothing is really working. Thanks
What brand of CDs are you using to burn to?
As a rule, I only use a few brands, and I have found that Maxell is the best, I will also use TDK or maybe a few select other brands.
Avoid Memorex at all costs! The absolute worst that I have experienced.
Exact same player, exact same CD copy, would not play Memorex at all, but worked great with Maxell.
