Hi all,
After days of reading through forums, I'm ready to ask some newbie questions about A/V setup. I'm all new to this game so be gentle
Here comes:
TV: Samsung 40A450
Receiver: Nakamichi AV-8 (no HDMI ports)
Cable box: Motorola (no coaxial ports)
Laptop: Asus A8Js (3.5mm audio port and DVI/VGA video port)
Right now, my set-top box is using component cables, 3 of the plugs out to TV, and 2 of the plugs out to the receiver. I'm wondering, if I get a 3-plug component cable ( or HDMI), and an optical cable, and run A/V with these, would I get better quality than my current setup?
For the laptop, I know I can use DVI/VGA cable to connect to TV for video, but what should I use for audio? Is there such a thing like 3.5mm to coaxial, or 3.5mm to optical cable? Or can I only use 3.5mm to RCA audio?
Thank you
