Hey everyone.. I've finally decided to upgrade past a sound bar and really need some advice on how to go from there.. I've settle on a 5.1 system. I will be mounting speakers on either side of the 65" TV .. center speaker will sit on the console below. I was planning on putting the sub on the corner wall right side of TV.
I'm wondering what to do with the rear speakers.. Where to mount them? trying to avoid putting them on stands as I will have to run wire under the sofa all the way around back to console. So I was wondering if maybe I can suspend them from ceiling behind sofa somehow?
Room size approx 21ftx20ft.. 9ft ceilings... the living room is part of an open floor plan.. to the left it opens into the kitchen/dining area which is a larger room.
Also since I'm on the subject of a 5.1 system. What would work well for a room that large..not really sure of my budget..but currently looking to spend 250ish per front speaker as well as about under 500 for a center speaker... sub..and rear..not worried about yet..
