First thing is download the user manual pdf for the avr. Then find the factory/microprocessor reset instructions so you can start with a clean slate. Then set it up just for your needs for your sources/speakers with the instructions for connections/setup in the manual. It should have manual as well as automatic setup instructions. Getting another microphone is a possibility too, but setup with an spl meter (even a phone app) shouldn't be too bad.
