Need Help finding Home Theater System for roughly around $1300
Agravier
Hi,and thanks for checking my post and any advice offered :),
I just replaced my old 61" DLP which died on me,for "Samsung UN55C8000 55" 1080p 3D LED HDTV" with Samsung BDC6900 3D Blu-ray player which pretty much broke my wife's bank when it comes to spending on home electronics:(,I was looking to also replace my surround system as well and keep it around $1300 so my wife doesn't smother me in my sleep!
Was looking to do this in the next couple of weeks,I was looking for a receiver that supports 3D and came up with TX-SR608 7.2 channel which I found it on Amazon listed for $494 which would leave me roughly $800 for speakers.
My question is for the price which speakers & sub would you guys recommend?
Second question is do you know/recommend another receiver that supports 3D other then the one I have found that's with-in my price range $1400 would be my pushing it max limit?
My room specs are 15x24 with 2 windows 10ft ceilings.
Any help would be greatly appreciated! thanks again :)
sholling
sholling
Congratulations on the nice TV. The little Onkyo 600 series are nice little receivers and I'm sure you will like it a lot. Just be sure that you stick with 8ohm speakers when you're out speaker shopping.
A good 5.1 speaker system, for $800 is a tall order. Just a subwoofer big enough to properly fill almost 4000cuft will set you back at least $500 plus shipping. If it were me I'd start by building the best 2.1 or 3.1 system I can afford and then go back and add the other pieces and maybe a second subwoofer when you have more money. Anyway here are two subs to start your search with. Hsu research is having a sale on their plain black VTF-2 MK3 (rated for up to 4000cuft) but that kills your budget. You could probably get by with a smaller Elemental Designs A2-300 but don't expect truly room shaking bass until you add a second one later on down the road.
The problem with recommending speakers is that they are very subjective. We all have different hearing and taste. Some like a somewhat bright speaker. Others like prefer a warmer sound. It just depends on your taste. (audio terms) All I can do is give you ideas about what to go listen to and then you need to get out and listen for yourself. Just keep in mind the tricks stores use. When comparing two speakers the loudest will sound better so when doing an A-B comparison make sure they are level matched. Make sure that the receivers are set flat (no tone controls in use) and no processing is being used. And be aware that the room acoustics and thus the sound of the speakers may be totally different once you get them home.
A popular recommendation for an excellent bang for the buck speakers that work really well in a large room is Infinity's Primus P362 tower speakers. You find them between $150 and $200 each depending a sales going on at the time. I'm told that they do benefit from a simple and cheap DYI mod but haven't heard the modded version. Anyway these should be really easy to drive loud and clean with that little Onkyo. Later when funds allow you could go back for the timbre matched PC350 center. And later down the road add a pair of P162 bookshelf speakers ($200/pr) as surrounds.
I'd also listen to some Boston Acoustic CS26 bookshelf speakers. You can find these online for as low as $80ea in black. I use them in my nearly 3000cuft master bedroom and drive them with the older Onkyo TX-SR606 and they sound pretty good for the price when backed by a properly sized subwoofer. Combine them with the timbre matched CS225 for about $150 and you have your 3 fronts for around $300. However these are rear ported so they do need some room behind and around them. Later you can add two more CS26s as surrounds.
I'd also give some Klipsch RB10 bookshelves ($250pr) a listen but they aren't for everyone. Klipsch tend to be easy to drive and very detailed but sound a bit bright for my taste. These are also rear ported like the Bostons and will need a little breathing room. The matched center is the RC-10 center (~$200).
You can watch Newegg.com for their fairly regular sales on Polk speakers. It seems like they are always having sales on one or another bookshelf, tower, or center. You'd have to piece it together but you could save some money.
Finally, members often recommend Behringer B2030P studio monitors ($131/pr shipped) as left, right, center, and surrounds. I love the ones in my office but I think that your room might be a tad too big for them. They are also a bit too industrial looking for most wives.
What I would avoid like a plague are small satellite speakers. You want something that will allow you to cross over to the subwoofer at 80hz or lower. That's the point below which it becomes harder to tell where the deep bass is coming from and you avoid the sonic equivalent of watching a ping pong game as the sound moves from the speakers to the subwoofer and back.
Oh and you'll save a ton buying cables and such from monoprice.com.
Good luck in your hunt.
skers_54
Receivers with HDMI 1.4 are just starting to come out, so they'll be fairly expensive. You probably won't find a good one for less than $500 for a while. If you can wait the prices will come down as more offerings become available. Otherwise the Onkyo is a solid unit if you can accept its limitations (which probably won't be an issue with speakers in your budget).
Since there isn't any 3D media available and won't be much for some time, you could get a cheap model now and replace it down the road. That would give you some more money for speakers. As far as I know, 1.3 and 1.4 will work equally well with what's out now on Blu-Ray. Gaming with the PS3 may be a different story but that may not be a priority for you.
3
30PlusRetlaw
Im in the same boat. I just order a set of speakers, center channel and a sub for $875. The Sub is an HSU STF-2. The speakers are the Polk audio monitor 70 and the center speaker is the Monitor CS2. The speakers where $179 each + 2.99 shipping the center channel was $99 bucks + $2.99 shipping. Im now looking for a receiver to complete the set up. Is a cheap HT set up but is a cheap one and better than my older one......none. Now. you will need to add the price of cables and surge protectors with line filter to protect your investment. I hope this help. The newegg sale is till tomorrow and the sub is direct from HSU.
Name Code Qty Each Options
STF-2 Powered Subwoofer - stf-2-black 1 349.00
Black
20 ft of Subwoofer cable-20-ft 1 10.00
Interconnect
Subtotal 359.00
Shipping 47.00
Tax 0.00
Total 406.00
2 x ($179.99) HA SPE POLK AUDIO MONITOR 70 C R $359.98
1 x ($99.99) HA SPE POLK AUDIO CS2 C R $99.99
Payment Term: American Express
Extended Warranty: $0.00
Subtotal: $459.97
Tax: $0.00
Shipping and Handling: $8.97
Total Amount: $468.94
Your Newegg.com Customer Service Team
Agravier
Thanks for the advice guys,
After going to a best buy's Magnolia store for a demo on some speakers,I realized that what I was expecting wont happen with my budget so,I'll opt for setting up a 3.1 then work my way to a 7.1 in the coming months thanks again guys for all the info.
I decided on going with:
Martin Logan Dynamo 700 10-inch Wireless Ready Sub-woofer
Martin Logan Motion 8 Center Channel Speaker
Martin Logan Motion 4 Bookshelf Speaker
I personally never heard of Martin Logan brand but it won me over on a demo,anyone familiar with these speakers that can share some personal insight if this is in-fact a solid choice I'm making?
bwilberg266
The Martin Logans are definitely good sounding speakers, but there are other speakers that could have given you more bang for your buck. Not sure how loud you like your movies, but if you're putting that much into the TV I'd say your looking for the best experience possible.
Granted my 5.1 took me about six months to put together, and I'm by no means saying my setup tops yours, because the Logans are good speakers, but I think I think I did pretty well for under $900.
Fronts: Polk Monitor 70's $300 from Newegg ($799 retail)
Center: Polk CS20 $130 from Polk Direct Ebay Store ($349 retail)
Surrounds: Polk TSI100's $150 from Best Buy ($199 retail)
Sub: ED A2-300 $300 from Classifieds on Audioholics ($415 retail)
Honestly not trying to put down the purchase but if you look around and read some posts you'll find that there are some great deals to be had out there. And for me, the hunt is half the fun.
I went for the Polks myself but as the suggestions above show there are plenty of great choices out there.
And as a side note I hate to think that you may have spent 700 on that sub when I know you could get a HSU VTF3-MK3 for that :(
