Need help figuring my house setup out.
Chadt
Hello, I just purchased a home that is pre-wired with wires going to the areas where TVs are hung as well as speakers in the ceiling throughout the house. There is a closet with a lot of wires and I have no idea where to start on getting this thing setup... please help!
everettT
everettT
Ratings
1,264 9 16
#2
I dont see many speaker wires, looks like all cat5/6 for the rooms. Is there another homerun? How many rooms and how many speakers in each.
tmurnin
Ratings
68
#3
The wires you are showing are all Ethernet (CAT5) cables for networking. Looks like they had a router next to the cable modem and hard-wired most of their connections. That’s nice to have but doesn’t do anything for your speakers. There must be another place where the speaker wires are run, maybe a closet or basement?
tmurnin
Ratings
68
#4
Wait, have you looked behind that white access panel? I think it says On-Q on the label, which is a home automation company that also sells speakers. Connections might be there.
L
Leemix
Ratings
71
#5
Last picture above/left of wireless it looks like the copper strands of speaker cables. Reddish and black jackets
everettT
everettT
Ratings
1,264 9 16
#6
Yup but dosent look like a lot. Regardless if they are not labeled, they need to be toned out.
Looks like a network switch is in order for sure.
2
2channel lover
Ratings
579
#9
As far as where those speaker wires are...looks like you're going to have some drywall patch up work ahead of you to find where those speaker wires were dropped..
Normally a contractor would run those to a home run location such as that closet.
