head full spec is : CEA-2006 Power Rating: 18 watts x 4 channels (at 4 ohms, 20-20kHz, 1% THD)
speaker's sensitivity: 94db and nominal impedance: 2ohm
Now I think there is a thing with running speakers wires in car somehow affects impedance (by increasing resistance??, maybe due to typically low gauge wiring??)
Not sure on this one, but lets assume 18w rms. Plugging the numbers here -
http://myhometheater.homestead.com/splcalculator.html
I assume 3ft distance and "corner" placement - i think it's safe assumption for car placement
I get 116db SPL at listening position, which is to say, unless you intend to compete in SPL competition or awake the dead - should be more than sufficient.
